[osgeo4w-dev] Re: [osgeo4w] #44: Gdal/Proj problems with Grass installation
OSGeo4W trac_osgeo4w at osgeo.org
Sun Feb 1 15:31:26 EST 2009
  Reporter:  cnielsen   |       Owner:  osgeo4w-dev at lists.osgeo.org
      Type:  defect     |      Status:  new
  Priority:  major      |   Milestone:
 Component:  Installer  |     Version:
Resolution:             |    Keywords:  grass, qgis
Comment (by zirneklitis):
 Similar problems arises due to placement of installation directory. I have
 placed the copy of installation CD on my network server. The installation
 from e.g. \\server\install\OSGeo4W\CD_20090127\setup.exe results in
 missing libraries. Mapping network drive
 (F:\OSGeo4W\CD_20090127\setup.exe) does not improve the situation. Only
 subst command solve the problem (subst G: F:\OSGeo4W\CD_20090127\).  I
 suppose, burning CD must be also solution.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/44#comment:2>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the osgeo4w-dev mailing list
