[osgeo4w-dev] package updates fail to install, no error
Matt Wilkie
maphew at gmail.com
Mon Feb 2 03:21:00 EST 2009
>I tried the test mode ini file and it upgraded both packages without
>any apparent problem. I'm surprised you are having problems.
Installing openev from the test ini worked okay at home. I might have messed
up my install at work. Time to remove it all and start from a clean slate I
guess. ;)
>I have taken the liberty of making a few changes in the setup package.
They all look good to me, more sensible than what I had. The trick of copy
the exe to a temp file before running to allow it be upgraded is a good one
-- simple and uncomplicated. I'll use that for apt too.
-matt
View this message in context: http://n2.nabble.com/package-updates-fail-to-install%2C-no-error-tp2248204p2256956.html
Sent from the osgeo4w-dev -- OSGeo Win32 Installer List mailing list archive at Nabble.com.
More information about the osgeo4w-dev
