[osgeo4w-dev] Problem with TIFFSetField in libtiff.dll
Wed Feb 4 15:24:53 EST 2009
Agustin Lobo wrote:
> Hi!
> After installing QGIS (and I've tried also installing everything with
> the  osGeo4w-setup)
> I try to run qgis and get (translating from Spanish locale):
> Cannot find the entry point of procedure TIFFSetField in libtiff.dll
> I've uninstalled and reinstalled libtiff, libtiff-dev, libgeotif severl times,
> same result. Any advice?
Agus,
Is there any chance you have a libtiff.dll in C:\windows\system32?
Does "gdalinfo --version" work properly in the OSGeo4W shell?
Best regards,
More information about the osgeo4w-dev mailing list
