[osgeo4w-dev] Problem with TIFFSetField in libtiff.dll
Agustin Lobo
Agustin.Lobo at ija.csic.es
Thu Feb 5 02:39:18 EST 2009
FRank,
Yes, moving away from system32 the libtiff.dll file solved the problem with QGIS
I also have
libjpeg.dll, libpng.dll and libpcd.dll in system32, should I move
away these files as well?
Nevertheles, running gdalinfo -version as you said gives the following:
C:\Documents and Settings\WIN-XP>gdalinfo -version
ERROR 1: Can't load requested DLL: C:\OSGeo4W\bin\gdalplugins\gdal_GRASS.dll
126: No se puede encontrar el m¾dulo especificado.
ERROR 1: Can't load requested DLL: C:\OSGeo4W\bin\gdalplugins\gdal_SDE.dll
Usage: gdalinfo [--help-general] [-mm] [-stats] [-nogcp] [-nomd]
[-noct] [-checksum] [-mdd domain]* datasetname
Also, when you say (in ticket #48)
" I now added a preremove script to the qgis packages that removes
the links from startmenu and desktop (and also fixed #48)"
Does this mean that we have to download another copy of osgeo4w-setup.exe ?
Thanks a lot,
Agus
Message: 5
Date: Wed, 04 Feb 2009 15:24:53 -0500
Subject: Re: [osgeo4w-dev] Problem with TIFFSetField in libtiff.dll
To: Agustin Lobo <Agustin.Lobo at ija.csic.es>
Cc: osgeo4w-dev at lists.osgeo.org
Message-ID: <4989F995.3030701 at pobox.com>
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
Agustin Lobo wrote:
> Hi!
> After installing QGIS (and I've tried also installing everything with
> the osGeo4w-setup)
> I try to run qgis and get (translating from Spanish locale):
> Cannot find the entry point of procedure TIFFSetField in libtiff.dll
> I've uninstalled and reinstalled libtiff, libtiff-dev, libgeotif severl times,
> same result. Any advice?
Agus,
Is there any chance you have a libtiff.dll in C:\windows\system32?
Does "gdalinfo --version" work properly in the OSGeo4W shell?
Best regards,
Dr. Agustin Lobo
Institut de Ciencies de la Terra "Jaume Almera" (CSIC)
Lluis Sole Sabaris s/n
08028 Barcelona
Spain
Tel. 34 934095410
Fax. 34 934110012
e-mail Agustin.Lobo at ija.csic.es
http://www.ija.csic.es/gt/obster
More information about the osgeo4w-dev
