[osgeo4w-dev] Re: osgeo4w-dev Digest, Vol 14, Issue 6
Isaac Ullah
iullah at asu.edu
Thu Feb 5 15:02:21 EST 2009
I do have a libtiff.dll in /C/Windows/system32. I see another user had
some success by removing this dll, but I do not wish to do this as
other programs (especially graphics software) on my system most
probably have this particular dll as a dependancy. Since i see that
hte OSgeo4W PATH variable incorporates all items in the system path, I
also tried to remove (temporarily) C\windows\system32\ from my system
path, but this was no good as the OSgeo4W shell would not load. Is
there any less drastic work around than simply deleting libtiff.dll
from system32?
Cheers,
Isaac
Message: 3
Date: Wed, 04 Feb 2009 19:01:33 -0500
Subject: Re: [osgeo4w-dev] more GRASS6.4RC3-2 problems.
To: Isaac Ullah <isaac.ullah at asu.edu>
Cc: osgeo4w-dev at lists.osgeo.org
Message-ID: <498A2C5D.4080604 at pobox.com>
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
Isaac Ullah wrote:
> I decided to startfrom scratch now, uninstalled everything, and
> deleted all old OSGEO4W files. This time I only selected to install
> GRASS fromm "desktop", letting it choose it's own default
> dependancies. i double checked, and I am using regular lib-jpeg now
> (notipp version). After install, I now get this error message: "The
> procedure entyr point TIFFMergeFieldInfo could not be found in the
> dynamic link library libtiff.dll". Click okay to this error, and then
> GRASS gives same r.proj error and quits.
> Is it possible that i have some other libtiff.dll? What are other
> possible culprits to make this not work seemingly only on my machine?
Isaac,
Could you look for a libtiff.dll in c:\Windows\system32?
More information about the osgeo4w-dev
