[osgeo4w-dev] Re: [osgeo4w] #49: uDig Start menu shortcut doesn't
	work
    trac_osgeo4w at osgeo.org
    Fri Feb  6 12:29:33 EST 2009
#49: uDig Start menu shortcut doesn't work
  Reporter:  mwtoews  |       Owner:  osgeo4w-dev at lists.osgeo.org
      Type:  defect   |      Status:  new
  Priority:  major    |   Milestone:
 Component:  Package  |     Version:
Resolution:           |    Keywords:  uDig
Changes (by maphew):
 * cc: moovida (added)
Comment:
 OSGEO4W_ROOT is set in `bin\udig.bat` at install time by the installer.
 I've looked at the shortcut install script and fixed two errors
 (attached):
  * the Start Menu link had the xxmklink `opath` and `arg` parameters
 reversed
  * Both Start Menu and Desktop links were pointing direct to the .exe
 instead of the .bat as you noted.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/49#comment:1>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the osgeo4w-dev
