#37: grass: wxpython gui issues
Reporter: jachym | Owner: osgeo4w-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone:
Component: Package | Version:
Resolution: | Keywords: GRASS
Comment (by jef):
Replying to [comment:17 martinl]:
> to be more clear I meant to obtain a receipt to compile wxvdigit
extension for grass package.
I initially compiled with Visual C++ 2008 Express Edition, which led to
similar results. Suspecting subtle compiler incompabilities I switched to
Visual C++ 7.1, which is what OSGeo4W's python is compiled with and the
default for distutils. Obviously that didn't help either.
I have attached what I use to build the extensions from the command prompt
started with {{{OSGeo4W-vc7.bat}}}. But I'm not sure if it's complete.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/37#comment:18>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
