[osgeo4w-dev] [osgeo4w] #57: duplicate gdal-grass and
grass-gdal-plugins packages
trac_osgeo4w at osgeo.org
Fri Feb 20 01:26:02 EST 2009
#57: duplicate gdal-grass and grass-gdal-plugins packages
Reporter: hamish | Owner: osgeo4w-dev at lists.osgeo.org
Type: enhancement | Status: new
Priority: minor | Milestone:
Component: Package | Version:
Keywords: grass gdal qgis |
it is a bit confusing that there is both a gdal-grass and a grass-gdal-
plugins package (by versions I see the second one is gdal v1.6, while
gdal-grass is v1.5)
Perhaps the grass-gdal-plugins one should be renamed gdal1.6-grass or
otherwise.
Also, I notice that the qgis-grass-plugin package depends on both grass
and qgis. Does it have to? I notice in the debian packaging that it only
depends on the equivalent of gdal-grass, and not the full grass package.
i.e. it should be able to be used to view GRASS data without a grass
binary install present. (??)
not really sure if any changes should be made here, but I thought I'd
raise the issue.
Hamish
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/57>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the osgeo4w-dev
