[osgeo4w-dev] Re: [osgeo4w] #13: "Local Package Directory" set to
C:\Programmi\Mozilla Firefox
trac_osgeo4w at osgeo.org
Fri Feb 20 19:04:49 EST 2009
#13: "Local Package Directory" set to C:\Programmi\Mozilla Firefox
Reporter: moovida | Owner: osgeo4w-dev at lists.osgeo.org
Type: enhancement | Status: new
Priority: minor | Milestone: Beta Release
Component: Installer | Version:
Resolution: | Keywords:
Comment (by mwtoews):
I had this too, but I realized it was because I double-clicked the
installer from Firefox's "Downloads" window, which I guess sets the
current working directory for the installer to be the same as the parent
application (Firefox).
If you double-clicked the installer from Windows Explorer in the location
where it downloaded (e.g., Desktop) then the local package directory will
be based from that location.
I'd expect the local package directory to default to the same directory as
the installer, not the app work directory.
E.g., path to installer:
C:\Documents and Settings\User\Desktop\osgeo4w-setup.exe
... should use a default local package directory:
I'd expect this to be a simple fix, except I don't know where to look.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/13#comment:1>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the osgeo4w-dev
