[osgeo4w-dev] [osgeo4w] #60: QGIS Start menu shortcut doesn't work
with non-default install directory
trac_osgeo4w at osgeo.org
Fri Feb 20 20:57:09 EST 2009
#60: QGIS Start menu shortcut doesn't work with non-default install directory
Reporter: mwtoews | Owner: osgeo4w-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone:
Component: Package | Version:
Keywords: qgis |
My setup is installed in a non-default location C:\gnu\OSGeo4W
The Start menu item has the correct target (with 2 extra spaces at end??):
C:\gnu\OSGeo4W\bin\qgis.bat
however, when it is selected from the Start menu, I see an error in a cmd
console:
The system cannot find the path specified.
and a Windows dialog with "Windows cannot find
'C:\OSGEO4W\apps\qgis\bin\qgis.exe'."
The problem is with qgis.bat:
@echo off
SET OSGEO4W_ROOT=C:\OSGeo4W
call "%OSGEO4W_ROOT%"\bin\o4w_env.bat
@echo off
set GDAL_DRIVER_PATH=%OSGEO4W_ROOT%\bin\gdalplugins
start "Quantum GIS" /B "%OSGEO4W_ROOT%"\apps\qgis\bin\qgis.exe %*
since it assumes that OSGEO4W_ROOT=C:\OSGeo4W which is not always true.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/60>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the osgeo4w-dev
