[osgeo4w-dev] Problems re-installing on WinXP 64
Matt Wilkie
matt.wilkie at gov.yk.ca
Wed Jan 14 12:50:18 EST 2009
Hi Ivan,
I use osgeo4w on win64 and have had different versions of gdal installed
at the same time. In my experience so far as long as I start from the
osgeo4w shell everything works, though I've not tried any java. Perhaps
in your uninstall/reinstall the osgeo4w command shell link was not
updated to the new location?
I do have to be careful that there are no gdal/python settings in the
permanent environment pointing to the wrong version. Run "set" with no
parameters from the shell. Settings to watch for cross contamination
include:
FWTOOLS_ROOT
GDAL_DATA
GEOTIFF_CSV
OSGEO4W_ROOT
PATH
PROJ_LIB
PYTHONPATH
PYTHON_INCLUDE
PYTHON_LIB
matt wilkie
Geographic Information,
Information Management and Technology,
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
http://environmentyukon.gov.yk.ca/geomatics/
Lucena, Ivan wrote:
> Hi there,
> I stalled OSGeo4W using "advanced install" so that I could select
> driver E: as the OSGeo4W root and select just some packages like:
> GDAL 1.5 Proj.4 OpenEV GDAL-Java
> I was able to use GDAL command line tools and OpenEV from that
> installation for a while.
> Later I setup a Java Web App from scratch in order to use the GDAL
> Java wrapper. That worked OK until I've got this error:
> --- GDALOpen failed - This is a BigTIFF file. BigTIFF is not
> supported by this version of GDAL and libtiff. ---
> Generated by this piece of code on my JSP class:
> dataset = gdal.Open( fileName, gdalconstConstants.GA_ReadOnly );
> if (dataset == null) { result = "GDALOpen failed - " +
> gdal.GetLastErrorMsg(); }
> I checked if the GTIFF driver was supporting BIGTiff by running
> gdalinfo and it looks like it was.
> I have several other GDAL environment on that machine so I decided to
> clean up a little bit and start from scratch the OSGeo4W
> installation.
> Now I can't get it to work anymore. Nothing. gdal tools, OpenEV and I
> also tried to install GRASS and QGIS each one of then complain about
> one dll or another.
> OpenEV:
> --------------------------- python.exe - Unable To Locate Component
> --------------------------- This application has failed to start
> because ogdi_32b1.dll was not found. Re-installing the application
> may fix this problem. --------------------------- OK
> Quantum GIS
> --------------------------- qgis.exe - Unable To Locate Component
> because QtCore4.dll was not found. Re-installing the application may
> GRASS:
> --------------------------- g.dirseps.exe - Unable To Locate
> Component --------------------------- This application has failed to
> start because zlib_osgeo.dll was not found. Re-installing the
> application may fix this problem. --------------------------- OK
> gdalinfo:
> --------------------------- gdalinfo.exe - Unable To Locate Component
> I tried to run the OSGeo4W again installing each one of the missing
> dll to the resolve those issues but it doesn't work. There is always
> something wrong or missing. I waste the last two days doing that.
> Does anybody has ever got in to that mess before? Any hint on how to
> get out of it? Was OSGeo4W installer tested on Win64 before? Is there
> a better way to uninstall and start from scratch then deleting the
> folder?
> Thank you so very much for any attempt to help.
> Ivan
> _______________________________________________ osgeo4w-dev mailing
> list osgeo4w-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/osgeo4w-dev
More information about the osgeo4w-dev
