[osgeo4w-dev] Problems re-installing on WinXP 64
Frank Warmerdam
warmerdam at pobox.com
Wed Jan 14 12:53:00 EST 2009
Lucena, Ivan wrote:
> Hi there,
> I have several other GDAL environment on that machine so I decided to clean up a little bit and start from scratch the OSGeo4W installation.
> Now I can't get it to work anymore. Nothing. gdal tools, OpenEV and I also tried to install GRASS and QGIS each one of then complain about one
> dll or another.
> I tried to run the OSGeo4W again installing each one of the missing dll to the resolve those issues but it doesn't work. There is always something
> wrong or missing. I waste the last two days doing that.
> Does anybody has ever got in to that mess before? Any hint on how to get out of it? Was OSGeo4W installer tested on Win64 before? Is there a
> better way to uninstall and start from scratch then deleting the folder?
> Thank you so very much for any attempt to help.
Ivan,
I'm rather at a loss as to why this would occur. The OSGeo4W installer
keeps track of installed packages in the OSGeo4W\etc directory. So if
you wipe the whole tree it should start with a clean sense of what
what is installed. The only thing I am aware of the setup program keeping
in the registry (outside the OSGeo4W tree) is the default settings for
where the cache, and install tree are.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
More information about the osgeo4w-dev
