[osgeo4w-dev] [osgeo4w] #35: DLL installation procedure
trac_osgeo4w at osgeo.org
Wed Jan 21 15:06:57 EST 2009
Reporter: jef | Owner: osgeo4w-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 1.0 Release
Component: Installer | Version: 1.0
Keywords: |
Some DLLs should be update DLLs in %WINDIR%\system32 instead of just
installing them into %OSGEO4W_ROOT%, if the are there.
E.g. it's likely to find an elder version of OpenSSL DLLs in
%WINDIR%\system32, which breaks everything using SSL (like libcurl and in
turn GDAL and everything that depends on it). This only applies to
EXEs/DLLs that are loaded from different path than %OSGEO4W_ROOT%\bin
(like Python extension, GRASS executables). About the DLL search order:
http://msdn.microsoft.com/en-us/library/ms682586(VS.85).aspx
We should have a tool that can retrieve the version of a DLL and if
necessary replaces it with a newer one. I found a code snippet that
should how to retrieve the DLL version on
http://www.codeproject.com/KB/DLL/dllversion.aspx
The update procedure should also consider replace on reboot, if the older
version of the DLL is currently in use (osgeo4w-setup has code to do
that).
A related posting of the qgis-developer list:
http://lists.osgeo.org/pipermail/qgis-developer/2009-January/005733.html
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/35>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the osgeo4w-dev
