[osgeo4w-dev] new application launch bat file template
Jürgen E. Fischer jef at norbit.de
Thu Jan 22 18:13:16 EST 2009
Hi Frank,
On Thu, 22. Jan 2009 at 15:36:51 -0500, Frank Warmerdam wrote:
> Also, are the existing .bat files broken?  Sometimes it is good to clarify
> "best practice" and apply it where convenient but there is no need to
> immediately force all packages to adopt the practice if their old approach
> works adequately.
I noticed that some of the batch files are in unix mode (ie. LF instead
of CRLF).
> I'm reasonably confident that several packages will not work properly
> if OSGeo4W is installed in a directory with a space in the path.
I think xxmklink had a problem with blank.  But I didn't take the time
to investigate - maybe I just didn't get the quotes right.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
More information about the osgeo4w-dev mailing list
