Re: [osgeo4w-dev] Problems re-installing on WinXP 64
Lucena, Ivan
ivan.lucena at pmldnet.com
Tue Jan 27 15:06:39 EST 2009
Hi Paul,
When I got to "proj_fw.dll is missing" I just renamed proj.dll to proj_fw.dll and it works.
Good luck,
Ivan
> -------Original Message-------
> From: Paul Mallas <pmallas at rsmas.miami.edu>
> Subject: [osgeo4w-dev] Problems re-installing on WinXP 64
> Sent: Jan 27 '09 19:29
> I seem to be having similar problems to Ivan - although I got a bit
> further with my install than he did. I have a 64 XP machine (I also run
> Cygwin - I don't know why but I feel I must mention it).
> For example, Ivan reported for
> qgis: This application has failed to start because QtCore4.dll
> was not found. Re-installing the application may fix this problem.
> gdalinfo: This application has failed to start because ogdi_32b1.dll
> and some other problem there was a problem with the zlib_osgeo.dll .
> I got around all of the by essentially installing all of the libraries
> with advanced install option (I started doing one library at a time but
> every new installed just required another, so I went ahead and installed
> all the libs). So, the programs did not complain about the above libs
> anymore. But they complained about new ones, that I seem to have
> installed, but cannot find in my distribution.
> Now, qgis complains that gdal16.dll cannot be found and openev complains
> about proj_fw.dll (gdal tools have same complaint). I cannot find these
> files in my distribution at all.
> Anyway, maybe this will provide a clue.
> osgeo4w-dev mailing list
> osgeo4w-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/osgeo4w-dev
More information about the osgeo4w-dev
