[osgeo4w-dev] [osgeo4w] #44: Gdal/Proj problems with Grass
installation
trac_osgeo4w at osgeo.org
Fri Jan 30 14:23:29 EST 2009
#44: Gdal/Proj problems with Grass installation
Reporter: cnielsen | Owner: osgeo4w-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone:
Component: Installer | Version:
Keywords: grass |
Several errors come up when starting grass, and it seems they relate to
gdal and proj.
Starting grass in text mode, g.region -p gives error:
"This application has failed to start because gdal16.dll was not found.
Re-installing the application may fix this problem"
The same error occurs with the test version 6.4.0RC3.
For related errors in tcltk mode see: http://lists.osgeo.org/pipermail/
grass-windows/2009-January/001658.html
The file gdal16.dll is not located anywhere within the OSGeo4W directory.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/44>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the osgeo4w-dev
