[osgeo4w-dev] package updates fail to install, no error
Matt Wilkie
matt.wilkie at gov.yk.ca
Fri Jan 30 20:02:59 EST 2009
Hello,
For tickets #21 (Start Menu localization) and #36 (call o4w_env.bat)
I've updated the following packages and put them online:
openev: etc/postinstall/openev.bat #change to %startmenu% syntax
setup: bin/ #added osgeo-setup_test-ini.bat
My process was to open each package, delve into the 'bin' and 'etc'
folders, examine *.bat, and update if necessary.
I skipped the gdal, grass, qgis packages and subpackages as all of those
seem to be under active change at the moment and I believe the
maintainers to be aware of this thread. I also skipped any packages
ending in "-devel".
I stopped at the testing phase (osgeo4w-setup.exe -t
http://download.osgeo.org/osgeo4w/setup_test.ini) because the updated
packages don't seem to install properly. Going to Advanced Install the
previous version is selected instead (1.9.0-3 in the case of openev).
Clicking on the version number column I can get it to increase to
1.9.0-4, but pressing Next after that fails. There is no error message,
it says it is complete, but the apps/openev tree is empty.
Can anyone see what I did wrong?
thanks
matt wilkie
Geographic Information,
Information Management and Technology,
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
http://environmentyukon.gov.yk.ca/geomatics/
More information about the osgeo4w-dev
