[osgeo4w-dev] Re: [osgeo4w] #7: Root install directory problems
 with folders with spaces (e.g. "C:/Program Files/")
    trac_osgeo4w at osgeo.org
    Tue Jun  9 12:11:04 EDT 2009
#7: Root install directory problems with folders with spaces (e.g. "C:/Program
Files/")
Reporter:  jmckenna  |        Owner:  osgeo4w-dev at lists.osgeo.org
    Type:  defect    |       Status:  new
Priority:  major     |    Component:  Installer
 Version:  Alpha     |   Resolution:
Keywords:            |
Comment (by hamish):
 FWIW the MSys maintainers have made it clear that they
 [https://sourceforge.net/tracker/?func=detail&atid=102435&aid=1511614&group_id=2435
 will not support spaces in path names], nor accept patches fixing those
 issues.
 With some patches to msys.bat however it is possible to run built binaries
 from `C:\Program Files\` although other bugs are likely to surface.
 That is not to say that we should not attempt to fix these bugs in our own
 shell scripts and batch files anyway, as unquoted variables can certainly
 have much more important implications than failure to run from a foreign
 sounding path name.
 Hamish
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/7#comment:2>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the osgeo4w-dev
