[osgeo4w-dev] Re: [osgeo4w] #63: Qgis does not start - message:
component not found libssl32.dll
trac_osgeo4w at osgeo.org
Sun Mar 15 11:51:44 EDT 2009
#63: Qgis does not start - message: component not found libssl32.dll
Reporter: ema | Owner: osgeo4w-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Component: Package
Version: | Resolution:
Keywords: qgis libssl32.dll |
Changes (by warmerdam):
* priority: blocker => major
* component: Installer => Package
Comment:
Ema,
I have uploaded the DLL dependency tracking program to:
http://home.gdal.org/tmp/depends.zip
If you would like, you can download this, and copy the contained
depends.exe into the C:\OSGeo4W\bin directory. Then in the OSGeo4W Shell
window you can do:
cd C:\OSGeo4W\apps\qgis\bin
depends.exe qgis.exe
This should launch the dependency viewer GUI. The top left pane is a DLL
tree. If you can find from that tree which DLL is attempting to load
libssl32.dll that might be quite helpful to us.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/63#comment:4>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the osgeo4w-dev
