[osgeo4w-dev] Re: [osgeo4w] #73: grass64 file has non-general file path
OSGeo4W trac_osgeo4w at osgeo.org
Mon Mar 30 09:54:49 EDT 2009
Reporter:  cnielsen  |        Owner:  osgeo4w-dev at lists.osgeo.org
    Type:  defect    |       Status:  new
Priority:  major     |    Component:  Package
 Version:            |   Resolution:
Keywords:  grass     |
Comment (by cnielsen):
 As the terminal seems to be unavailable when starting with the grass.bat
 icon, personally I would like that file to be left in place. As far as I
 have found, the only way to keep a functional terminal is to open msys and
 start grass using this grass64 file (after adding /osgeo4w/apps/grass/bin
 to PATH in /etc/ini/grass.bat) see
 <http://trac.osgeo.org/grass/ticket/533>
 Also when using msys for other functions (compiling, etc.) it is nice to
 be able to still start grass from the command line. Is there some way to
 make both of these function?
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/73#comment:2>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the osgeo4w-dev mailing list
