[osgeo4w-dev] Re: [osgeo4w] #73: grass64 file has non-general file
path
trac_osgeo4w at osgeo.org
Mon Mar 30 10:35:03 EDT 2009
#73: grass64 file has non-general file path
Reporter: cnielsen | Owner: osgeo4w-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Component: Package
Version: | Resolution:
Keywords: grass |
Comment (by jef):
Replying to [comment:2 cnielsen]:
> As the terminal seems to be unavailable when starting with the grass.bat
icon, personally I would like that file to be left in place.
hm, on Windows {{{grass64.bat}}} and not the {{{grass64}}} seems to be the
intended way to start GRASS. Therefore {{{grass64.bat}}} was customized
and copied to /bin for OSGeo4W.
It starts {{{apps/grass/grass-6.4.0svn/etc/Init.bat}}} which in turn
starts the text or GUI interface and doesn't leave a command prompt open
in the latter case.
So if the current behaviour is not intended {{{Init.bat}}} is the place to
change that.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/73#comment:3>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the osgeo4w-dev
