[osgeo4w-dev] Re: [osgeo4w] #73: grass64 file has non-general file
path
trac_osgeo4w at osgeo.org
Mon Mar 30 10:49:45 EDT 2009
#73: grass64 file has non-general file path
Reporter: cnielsen | Owner: osgeo4w-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Component: Package
Version: | Resolution:
Keywords: grass |
Comment (by cnielsen):
Yes as far as I know that's all correct.
I have found a way to modify {{{msys.bat}}} to automatically start grass
(using the {{{grass64}}} file, and therefore {{{init.sh}}}) and have the
terminal left available. I think having a terminal is fairly fundamental
to grass's functionality, so maybe this approach would be better than
having a whole other windows startup system (unless there are more
fundamental reasons to having the {{{grass.bat/init.bat}}}).
Basically I just changed line 95 of {{{msys.bat}}} ({{{start
%WD%rxvt}}}...) to execute {{{grass64}}}.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/73#comment:4>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the osgeo4w-dev
