[osgeo4w-dev] Convert Arcinfo binary coverages using the ogr_csharp.dll
Alex Mandel tech_dev at wildintellect.com
Tue Oct 27 23:19:50 EDT 2009
Gerry James wrote:
> I am trying to embed a utility in a VB.NET application that will convert an
> ArcInfo coverage (not e00) to a shapefile.  I was able to import the ogr and
> osr dlls to the project and can convert other file formats quite easily but
> not these AI coverages.  It apparently won't even open the data set with
> Ogr.Open([coveragename], 0).  I have tried using each of the .adf files as
> coverage names as well as the parent directory (as should be the case) and
> still it won't open the dataset.
> Can someone point me in the right direction for this?
> Thanks
> Gerry
Looking at the docs
http://www.gdal.org/ogr/drv_avcbin.html
If you have an adf file it sounds like you have GRID on your hands, not
a vector dataset.
"If the directory contains files with names like w001001.adf then the
coverage is a grid coverage suitable to read with GDAL, not a vector
coverage supported by OGR."
Keep in mind this list is specifically for discussing the OSGeo4W
installation tool. Questions about specific sub-products outside of the
installation should be addressed to that project.
I would highly recommend you join the GDAL mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
Alex
More information about the osgeo4w-dev mailing list
