[osgeo4w-dev] GDAL Python Scripts on Windows 7?
Jürgen E. Fischer
jef at norbit.de
Fri Aug 20 15:23:46 EDT 2010
Hi Jeff,
On Fri, 20. Aug 2010 at 14:01:45 -0400, Jeff Ruby wrote:
> 1. I'm trying to run the GDAL python scripts I get a dialog box with
> the following error: "The ordinal 284 could not be located in the
> dynamic link library SSLEAY32.dll"
I order to get SSL support in libpq to I recently updated both the openssl
libpq package.
You probably have a SSLEAY32.dll in your system32 that overrides the one
installed with OSGeo4W.
It should have been upgraded by dllupdate from the postinstall batchfile.
Could you please check in the %OSGEO4W_ROOT%/var/log/setup.log.full and report
what happened?
> 2. Is there anyway to get the python scripts working with GDAL 1.7
> without having to do a lot of manual copying and moving of files? I
> see GDAL-python and GDAL16-python libs but nothing for GDAL 1.7.
QGIS would also benefit from GDAL 1.7 python bindings...
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-20
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
More information about the osgeo4w-dev
