[osgeo4w-dev] Packaging instructions - questions
Jeff McKenna
jmckenna at gatewaygeomatics.com
Tue Feb 9 02:01:46 EST 2010
Hello everyone,
As I have not packaged anything for OSGeo4W in a while, I have some
basic questions (sorry for the dumb questions following):
- I see that the setup.ini regeneration process has been changed to
running Web scripts, instead of tunneling to the server. Cool. However
I'm not exactly sure what should be happening when I run this according
to the wiki instructions:
http://download.osgeo.org/osgeo4w/osgeo-setup_test-ini.bat (I only see
the contents of that file displayed in the browser) I assumed I should
run something locally like 'setup.exe -t
http://download.osgeo.org/osgeo4w/setup_test.ini', not on
download.osgeo.org (please correct me, and I can update the wiki
instructions if need be)
- I'm sure others have hit this issue before (including myself?), but,
how do we handle package versions when the cygwin setup code thinks the
new package is a [prev] one? e.g. Cygwin setup code thinks
'apache-2.2.14' is older than all of the other apache packages
('apache-2.2.8') [http://download.osgeo.org/osgeo4w/release/apache/].
Thanks.
-jeff
More information about the osgeo4w-dev
