[osgeo4w-dev] Packaging instructions - questions
Jeff McKenna jmckenna at gatewaygeomatics.com
Tue Feb 9 02:12:38 EST 2010
Jeff McKenna wrote:
> Hello everyone,
> As I have not packaged anything for OSGeo4W in a while, I have some
> basic questions (sorry for the dumb questions following):
> - I see that the setup.ini regeneration process has been changed to
> running Web scripts, instead of tunneling to the server. Cool.  However
> I'm not exactly sure what should be happening when I run this according
> to the wiki instructions:
> http://download.osgeo.org/osgeo4w/osgeo-setup_test-ini.bat (I only see
> the contents of that file displayed in the browser)  I assumed I should
> run something locally like 'setup.exe -t
> http://download.osgeo.org/osgeo4w/setup_test.ini', not on
> download.osgeo.org (please correct me, and I can update the wiki
> instructions if need be)
> - I'm sure others have hit this issue before (including myself?), but,
> how do we handle package versions when the cygwin setup code thinks the
> new package is a [prev] one?  e.g. Cygwin setup code thinks
> 'apache-2.2.14' is older than all of the other apache packages
> ('apache-2.2.8') [http://download.osgeo.org/osgeo4w/release/apache/].
Ah ok I wasn't going crazy - this same package versions issue came up a
year ago (http://trac.osgeo.org/osgeo4w/ticket/23).  I will do some
reading on setup.hint now (http://cygwin.com/setup.html).
-jeff
More information about the osgeo4w-dev mailing list
