[osgeo4w-dev] Packaging instructions - questions
Jeff McKenna
jmckenna at gatewaygeomatics.com
Tue Feb 9 03:59:47 EST 2010
Jeff McKenna wrote:
> Jeff McKenna wrote:
>> Hello everyone,
>> As I have not packaged anything for OSGeo4W in a while, I have some
>> basic questions (sorry for the dumb questions following):
>> - I see that the setup.ini regeneration process has been changed to
>> running Web scripts, instead of tunneling to the server. Cool.
>> However I'm not exactly sure what should be happening when I run this
>> according to the wiki instructions:
>> http://download.osgeo.org/osgeo4w/osgeo-setup_test-ini.bat (I only see
>> the contents of that file displayed in the browser) I assumed I
>> should run something locally like 'setup.exe -t
>> http://download.osgeo.org/osgeo4w/setup_test.ini', not on
>> download.osgeo.org (please correct me, and I can update the wiki
>> instructions if need be)
>> - I'm sure others have hit this issue before (including myself?), but,
>> how do we handle package versions when the cygwin setup code thinks
>> the new package is a [prev] one? e.g. Cygwin setup code thinks
>> 'apache-2.2.14' is older than all of the other apache packages
>> ('apache-2.2.8') [http://download.osgeo.org/osgeo4w/release/apache/].
> Ah ok I wasn't going crazy - this same package versions issue came up a
> year ago (http://trac.osgeo.org/osgeo4w/ticket/23). I will do some
> reading on setup.hint now (http://cygwin.com/setup.html).
I have updated the instructions with this version note
(http://trac.osgeo.org/osgeo4w/wiki/PackagingInstructions).
-jeff
More information about the osgeo4w-dev
