[osgeo4w-dev] Express Install : 1 Go
Yves Jacolin
yves.jacolin at camptocamp.com
Mon Feb 22 11:34:23 EST 2010
I tried the Express Install this afternoon. I think 'Express' is not a good
name for this ;) "Easy" would be better as the express install is quiet long
and take a lot of space. I know that it is not easy to choose package ...
The problem is when space is not enough, I had some problem as the install
process didn't seems to finish correctly, even if OSGeo4w installer didn't say
anything. However some conf file always have @osgeo4w@ variable!
Anyway, some question: is it possible to preselect in any way some packages
which will be installed in the Express way?
Does the Advanced way is supposed to install dependancies? For exemple, if I
check ms_mapserver_ogc (this is not the exactly right name), does apache,
mapserver, etc. will be installed? It seems not :/
I would like to allow user to install application easily without take care of
dependancy neither to get 1Go used with all packages.
Finally, why postgresql/postgis is not available. in OSGeo4W? Licence issue?
Thanks,
Y.
Yves Jacolin
Responsable Formation et Support
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 26 57 98
Fax : 04 79 70 15 81
Mail : yves.jacolin at camptocamp.com
http://www.camptocamp.com
More information about the osgeo4w-dev
