[osgeo4w-dev] Express Install : 1 Go
Yves Jacolin yves.jacolin at camptocamp.com
Tue Feb 23 03:02:56 EST 2010
Hello,
All of your answer are interesting. Just for the one quoted below: when I said
"is it possible to preselect in any way some packages which will be installed
in the Express way" I didn't mean by the user but rather by someone like me
who wants to use OSGeo4W to create a CD/USB.
I mean I understand that you have to choose most of packages in express
install but maybe it exists a parameter in the setup.ini to tell to the
installer that this package will be (or not) installed via express install (ie
express: true)
If you think this interesting I can create a ticket for this.
Thanks,
Le mardi 23 février 2010 03:35:32, Jeff McKenna a écrit :
> >> Anyway, some question: is it possible to preselect in any way some
> >> packages which will be installed in the Express way?
> maybe make a comment in http://trac.osgeo.org/osgeo4w/ticket/143 and
> join the discussion.
> > Yes, but they are pre-selected by us, the OSGeo4W developers.  If the
> > user were to select them then it's an advanced install!
Yves Jacolin
Responsable Formation et Support
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 26 57 98
Fax : 04 79 70 15 81
Mail : yves.jacolin at camptocamp.com
http://www.camptocamp.com
More information about the osgeo4w-dev mailing list
