[osgeo4w-dev] Re: [osgeo4w] #151: installation from local package
don't check the dependencies
trac_osgeo4w at osgeo.org
Tue Feb 23 10:35:54 EST 2010
#151: installation from local package don't check the dependencies
Reporter: yjacolin | Owner: osgeo4w-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Component: Installer
Version: | Resolution:
Keywords: |
Comment (by warmerdam):
I don't understand what mode is being used instead of internet mode. Have
you already downloaded all packages and the setup.ini to a local cache
directory and are operating against that? Is this a "first run" of
osgeo4w setup on the system or is there an existing installed tree?
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/151#comment:1>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the osgeo4w-dev
