[osgeo4w-dev] Re: [osgeo4w] #151: installation from local package
 don't check the dependencies
    trac_osgeo4w at osgeo.org
    Tue Feb 23 10:50:20 EST 2010
#151: installation from local package don't check the dependencies
Reporter:  yjacolin  |        Owner:  osgeo4w-dev at lists.osgeo.org
    Type:  defect    |       Status:  new
Priority:  major     |    Component:  Installer
 Version:            |   Resolution:
Keywords:            |
Comment (by yjacolin):
 Sorry, yes after "advanced install" choose 'Install from Local directory",
 here is the new process:
  1. run osgeo4_setup.exe
  2. choose "advanced install"
  3. choose Install from Local directory
  3. choose the install dir and the local dir where packages are
  3. click on "install" until "uninstall" appears to unselect all pakcages
  4. find and select ms_ogc_workshop
  5. click on next until the end.
 All the packages and the setup.ini.bz2 are already on a CD
   Is this a "first run" of osgeo4w setup on the system or is there an
 existing installed tree?
 I tried with a first run and after an existing installed tree.
 Y.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/151#comment:2>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the osgeo4w-dev
