[osgeo4w-dev] [osgeo4w] #170: restore referenced qgis-dev package
trac_osgeo4w at osgeo.org
Fri Jul 16 03:00:38 EDT 2010
Reporter: jef | Owner: osgeo4w-dev@…
Type: task | Status: new
Priority: major | Component: Package
Version: | Keywords:
currently qgis-dev is uninstallable. The setup.ini references a non-
existing file.
Please restore the latest qgis-dev package from
[[http://buten.norbit.de/~jef/qgis-dev-1.5.0-145.tar.bz2 qgis-
dev-1.5.0-145]] (original upload) to release/qgis/qgis-dev.
I also see that setup.ini still lists gdal16 as dependency. Although that
matches setup.hint, I thought I already changed it to reference gdal17.
Please also consider updating it from
[[http://buten.norbit.de/~jef/setup.hint setup.hint]] and rebuilding
setup.ini.
And finally we're going to branch the 1.5 release this weekend and call
for packages. Is there an (rough) ETA when upload.osgeo.org will be
available again?
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/170>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the osgeo4w-dev
