[osgeo4w-dev] ecw plugin: 3.3 SDK no longer available
    Frank Warmerdam
    warmerdam at pobox.com
    Tue Jun  1 16:53:53 EDT 2010
Matt Wilkie wrote:
> Hi Folks,
> I discovered today the 3.3 SDK for ECW is no longer available. It is
> expected to be replaced by 4.1 sometime this month. (source
> http://www.erdas.com/Products/ERDASProductInformation/tabid/84/currentid/1142/default.aspx)
> Thus the instructions at http://trac.osgeo.org/osgeo4w/wiki/pkg-gdal-ecw
> are currently in error. Is this likely a short term problem (e.g. the
> 4.1 SDK, when available, will just work)?
Matt,
It is unlikely that the 4.1 SDK will work without a recompile.  There has
also been problems with people actually getting the SDK without lots of
messy arrangements.
Best regards,
More information about the osgeo4w-dev
