[osgeo4w-dev] Re: [osgeo4w] #161: gdal utilities issues
trac_osgeo4w at osgeo.org
Tue Mar 16 09:46:42 EDT 2010
Reporter: lutra | Owner: osgeo4w-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Component: Package
Version: | Resolution:
Keywords: gdal, gdal utilities |
Comment (by brushtyler):
Replying to [comment:2 jef]:
> If you want to use GDAL 1.6 from the command line you need to run
> {{{gdal16.bat}}} manually first. Running GDAL 1.5 binaries after that
is
> probably not a good idea either.
> [[BR]]
> If you start QGIS using the desktop/start menu link {{{gdal16.bat}}} is
run
> automatically. So everything should be fine from within QGIS.
I use qgis-dev but no gdal16 .exe tools seems work fine.
I tried to call the gdal16.bat too, but nothing.
I'm enough sure this is no a dlls conflict. If you remember time ago I
wrote in ML about this problem.
I've tried installing only gdal16 (no gdal lib): each .exe tool started
its execution, but it crashed before exit (from terminal too). [[BR]]
So I think these are 2 different problems, I don't know if are
related.[[BR]]
1) gdal16 executables crashes[[BR]]
2) gdal python tools require to work both gdal-python and gdal16-python
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/161#comment:4>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the osgeo4w-dev
