[osgeo4w-dev] Re: [osgeo4w] #161: gdal utilities issues
OSGeo4W trac_osgeo4w at osgeo.org
Tue Mar 16 09:55:50 EDT 2010
Reporter:  lutra                 |        Owner:  osgeo4w-dev at lists.osgeo.org
    Type:  defect                |       Status:  new
Priority:  major                 |    Component:  Package
 Version:                        |   Resolution:
Keywords:  gdal, gdal utilities  |
Comment (by jef):
 Replying to [comment:3 lutra]:
 > Traceback (most recent call last):
 >   File "c:/osgeo4w/apps/gdal-16/bin/gdal_merge.py", line 31, in <module>
 >     import gdal
 > ImportError: No module named gdal
 Just to make sure: you are aware that you need to call {{{gdal_merge}}}
 from the "shell" from which you started {{{gdal16.bat}}}?
 But from what brushtyler said this is probably a Vista/W7 issue.  Could
 you run [[http://www.dependencywalker.com/ depends]] on
 {{{%OSGEO4W_ROOT%/apps/gdal-16/pymod/osgeo/_gdal.pyd}}}?
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/161#comment:5>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the osgeo4w-dev mailing list
