[osgeo4w-dev] Unattended install
Jeremy Palmer JPalmer at linz.govt.nz
Fri May 7 01:26:25 EDT 2010
I'm trying to setup a local installation and then create a batch file for an unattended install. I've tried to complete the install as described in the FAQ, but I can't get it to work. The command I'm using is:
setup.exe -q --local-install --root C:\Dev\SPI\Test -l "C:\Dev\SPI\OSGeo4W\release"
A screen flashes up and the installer finishes without installing any packages. All of my packages live in C:\Dev\SPI\OSGeo4W\release, i.e. C:\Dev\SPI\OSGeo4W\release\curl\curl-7.15.1-2.tar.bz2 etc...
The setup.ini was generated without error using the "genini" script, and lives in C:\Dev\SPI\OSGeo4W\setup.ini.
The install log in C:\Dev\SPI\Test\var\log\setup.log is:
2010/05/07 17:19:59 Starting cygwin install, version 2.579
2010/05/07 17:19:59 Current Directory: C:\Dev\SPI\OSGeo4W\release
2010/05/07 17:19:59 Changing gid to Users
2010/05/07 17:19:59 Could not open service McShield for query, start and stop. McAfee may not be installed, or we don't have access.
2010/05/07 17:19:59 root: C:\Dev\SPI\Test binary system
2010/05/07 17:19:59 Selected local directory: C:\Dev\SPI\OSGeo4W\release
2010/05/07 17:20:00 Ending cygwin install
Is it not finding the setup.ini file?
Cheers
Jeremy
______________________________________________________________________________________________________
This message contains information, which is confidential and may be subject to legal privilege.
If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message.
If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message.
LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ.
Thank you.
More information about the osgeo4w-dev mailing list
