[osgeo4w-dev] Re: [osgeo4w] #166: Invalid package qt4-doc-4.5.2-5
trac_osgeo4w at osgeo.org
Fri May 7 02:51:30 EDT 2010
Reporter: alexbruy | Owner: osgeo4w-dev at lists.osgeo.org
Type: defect | Status: reopened
Priority: major | Component: Package
Version: | Resolution:
Keywords: qt4-doc |
Changes (by alexbruy):
* status: closed => reopened
* resolution: fixed =>
Comment:
Problem still there. Packages qt4-doc-4.5.2-5.tar.bz2, qt4-
doc-4.5.2-6.tar.bz2 and qt4-doc-4.5.2-7.tar.bz2 can't be installed or
uncompressed with external archiever. Here is log from OSGeo4W msys
console when I try to unpack qt4-doc-4.5.2-7.tar.bz2
apps/Qt4/doc/html/images/designer-resources-using.png
apps/Qt4/doc/html/images/designer-screenshot-small.png
bzip2: Compressed file ends unexpectedly;
perhaps it is corrupted? *Possible* reason follows.
bzip2: error 0
Input file = (stdin), output file = (stdout)
It is possible that the compressed file(s) have become corrupted.
You can use the -tvv option to test integrity of such files.
You can use the `bzip2recover' program to *attempt* to recover
data from undamaged sections of corrupted files.
tar: 296 garbage bytes ignored at end of archive
tar: Unexpected EOF in archive
tar: Error is not recoverable: exiting now
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/166#comment:2>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the osgeo4w-dev
