[osgeo4w-dev] proj refactoring, gdal17-ecw
Matt Wilkie
matt.wilkie at gov.yk.ca
Thu Oct 21 15:26:18 EDT 2010
Many thanks for this work Frank!
> http://trac.osgeo.org/osgeo4w/wiki/pkg-gdal17-ecw
After following these instructions gdalinfo works, in that it reports
info I expect, but throws up a crash dialog (attached). I'm using 64bit
Win7 and put the ecw dll's in %osgeo4w_root%\bin.
16/09/2010 04:07 AM 54,784 NCScnet4.dll
16/09/2010 04:28 AM 2,247,168 NCSEcw4_RO.dll
16/09/2010 04:07 AM 385,024 NCSUtil4.dll
16/09/2010 01:17 AM 220,336 tbb.dll
It is quite possible that I have another ECW dll somewhere in PATH. If
so I've not found it yet though. Is it possible to use dllupdate to
locate dupes? I tried a few things with it but it came up empty.
C:\>path=%path%;c:\OSGeo4W\bin
C:\>dllupdate "c:\Program Files (x86)\ERDAS\ERDAS ECW JPEG2000 Read
SDK\redistributable\vc90\win32\NCScnet4.dll"
SDK\redistributable\vc90\win32\NCScnet4.dll" c:\Windows\System32
SDK\redistributable\vc90\win32\NCScnet4.dll" c:\Windows\SysWOW64
matt wilkie
Geomatics Analyst
Information Management and Technology
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
http://environmentyukon.gov.yk.ca/geomatics/
On 20/10/2010 7:12 PM, Frank Warmerdam wrote:
> Folks,
> Today I have refreshed and refactored the PROJ.4 package. This includes
> splitting the HPGN (HARN) datum shift grid files into a separate package
> (proj-hpgn) and the other grid shift files (proj-datumgrid). This is to
> avoid these fairly large packages from having to be re-downloaded every
> time the proj dll/exe package is updated. The grid shift files will
> presumably change rarely. The two grid shift package are dependencies
> of proj and so will always be installed if proj is.
> I also introduced a new proj-vdatum vertical datum grid shift package which
> is very large (40MB or so). It is used by PROJ, but due to it's size, and
> the relative rarity of use I have not made it a dependency of proj. It will
> need to be installed specifically by the user.
> Today I also addressed the request for a gdal17-ecw plugin package. To do
> this I had to update the GDAL ECW driver to work with the ECW SDK
> currently available from Erdas (4.1 20100920), and backported those changes
> to 1.7. Note that the most recent Erdas SDK is read-only, so it is not
> possible to use the gdal17-ecw plugin to produce ECW or JPEG2000 files.
> The new package page discussed the steps to download the sdk from Erdas
> which each end user will need to do. There is also now an emailed password
> to install the SDK and I believe the terms of the agreement are different so
> caution should be used reviewing the use agreement.
> I will note the plugin is built with VS2008 while GDAL 1.7 itself is built
> with VS2003. This is a somewhat dangerous mixture, but I didn't have any
> issues in my simple local testing. I now have a virtual machine setup
> with VS2008 and I hope to migrate to using it for GDAL 1.8 and other
> packages as appropriate. I believe the msvcrt package already includes
> the runtime components for VS2008.
> Tonight and tomorrow I also plan to refresh the libgeotiff, and gdal-dev
> packages. If anything unusual comes out of those efforts, I'll notify
> this list.
> Best regards,
Name: OSGeo4W - gdalinfo WhitehorseOrtho_1m.png
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20101021/84015289/OSGeo4W-gdalinfoWhitehorseOrtho_1m-0001.png
More information about the osgeo4w-dev
