[osgeo4w-dev] proj refactoring, gdal17-ecw
Richard Greenwood
richard.greenwood at gmail.com
Mon Oct 25 09:13:03 EDT 2010
On Thu, Oct 21, 2010 at 1:26 PM, Matt Wilkie <matt.wilkie at gov.yk.ca> wrote:
> Many thanks for this work Frank!
>> http://trac.osgeo.org/osgeo4w/wiki/pkg-gdal17-ecw
> After following these instructions gdalinfo works, in that it reports info I
> expect, but throws up a crash dialog (attached). I'm using 64bit Win7 and
> put the ecw dll's in %osgeo4w_root%\bin.
> 16/09/2010 04:07 AM 54,784 NCScnet4.dll
> 16/09/2010 04:28 AM 2,247,168 NCSEcw4_RO.dll
> 16/09/2010 04:07 AM 385,024 NCSUtil4.dll
> 16/09/2010 01:17 AM 220,336 tbb.dll
> It is quite possible that I have another ECW dll somewhere in PATH. If so
> I've not found it yet though. Is it possible to use dllupdate to locate
> dupes? I tried a few things with it but it came up empty.
You might try:
which -a NCScnet4.dll
to find all instances of the .dll in your path. 'which' is a standard
*NIX command, but a windows version can be found here:
http://gnuwin32.sourceforge.net/packages/which.htm
Regards,
Rich
Richard Greenwood
www.greenwoodmap.com
More information about the osgeo4w-dev
