[osgeo4w-dev] proj refactoring, gdal17-ecw
Matt Wilkie
matt.wilkie at gov.yk.ca
Mon Oct 25 13:01:55 EDT 2010
> You might try:
> which -a NCScnet4.dll
> to find all instances of the .dll in your path. 'which' is a standard
> *NIX command, but a windows version can be found here:
> http://gnuwin32.sourceforge.net/packages/which.htm
thanks, that's better than the batch file I spent most of a day brewing. :)
Results: all clean, only one copy of those dll's in PATH.
-matt
More information about the osgeo4w-dev
