[osgeo4w-dev] libintl-8.dll
Jürgen E. Fischer
jef at norbit.de
Tue Apr 26 14:19:03 EDT 2011
Hi Frank,
On Tue, 26. Apr 2011 at 11:38:34 -0400, Frank Warmerdam wrote:
>> /The program can't start because libintl-8.dll is missing from your computer.
>> Try reinstalling the program to fix this problem. /
Maybe that's the "usual" case of having a version of that DLL in system32
that doesn't work with osgeo4w.
> As an aside I see the libpq 8.3 package includes iconv and a bunch of stuff
> that might well conflict with other packages. I'm not sure what the reasoning
> was to package it this way.
That are repackaged binaries from postgresql - including the DLL it was build
against. AFAIK there's no conflict in osgeo4w with those files.
But I made a little script to verify: It found following problems in
non-obsolete packages:
gzipped archives:
gdal/gdal15dll/gdal-1.5.4-0.tar.bz2
xerces-c/xerces-c-vc9-devel/xerces-c-vc9-3.1.1-3-devel.tar.bz2
File conflicts:
qgis/qgis-grass-plugin/qgis-grass-plugin-1.6.0-4.tar.bz2 qgis/qgis/qgis-1.6.0-5.tar.bz2 (grass icons)
msvcrt/msvcrt-1.0.1-5.tar.bz2 vs. java/java-1.6.0_17-1.tar.bz2 (MS runtime DLLs)
gdal/gdal-java/gdal-java-1.8.0-1.tar.bz2 vs. java/java-1.6.0_17-1.tar.bz2 (GDAL JAVA DLLs)
gdal/gdal-sde90/gdal-sde90-1.5.0-1.tar.bz2 vs. gdal/gdal-sde91/gdal-sde91-1.5.0-1.tar.bz2 vs. gdal/gdal-sde92/gdal-sde92-1.5.0-1.tar.bz2 (SDE plugins)
gdal/gdal-mrsid/gdal-mrsid-1.8.0-4.tar.bz2 vs. gdal/gdal17-mrsid/gdal17-mrsid-1.7.2-1.tar.bz2 vs. gdal/gdal16-mrsid/gdal16-mrsid-1.6.0-1.tar.bz2 (LizardTech DLLs)
libtiff/libtiff-bin/libtiff-bin-4.0.0dev-9.tar.bz2 vs. libtiff/libtiff-4.0.0dev-90.tar.bz2 (executables)
libtiff/libtiff-devel/libtiff-devel-4.0.0dev-9.tar.bz2 vs. libtiff/libtiff-4.0.0dev-90.tar.bz2 (headers and library)
mapserver/mapserver56/mapserver-5.6.5-1.tar.bz2 vs. mapserver/mapserver-5.2.2-2.tar.bz2 (everything?)
php_mapscript/php_mapscript-5.2.2-2.tar.bz2 vs. php_mapscript/php_mapscript56/php_mapscript-5.6.5-1.tar.bz2 (ditto)
jpeg/libjpeg-ipp/libjpeg-ipp-1.0-1.tar.bz2 vs. jpeg/libjpeg/libjpeg-6b-5.tar.bz2 (jpeg_osgeo.dll)
jpeg/libjpeg-devel/libjpeg-devel-6b-3.tar.bz2 vs. in jpeg/libjpeg/libjpeg-6b-5.tar.bz2 (jinclude.h)
gdal/gdal-1.8.0-2.tar.bz2 vs. gd/gd-devel/gd-devel-2.0.35-1.tar.bz2 (gdal_i.lib)
I suppose the QGIS problem can wait for the next release - not sure about the
others...
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-20
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
More information about the osgeo4w-dev
