[osgeo4w-dev] OSGeo4W.bat does not set gdal plugins directory
into path
Matt Wilkie
matt.wilkie at gov.yk.ca
Fri Dec 16 15:12:16 EST 2011
Hi Jukka,
I attempted to replicate this by:
0. running `gdalinfo --formtats |grep oracle` (nothing reported)
1. installing gdal-oracle package (using apt)
2. running `gdalinfo --formtats |grep oracle` again, in the same shell
session, with result:
C:\>gdalinfo --formats |grep -i oracle
GeoRaster (rw+): Oracle Spatial GeoRaster
Investigation of the file system revealed that the oci plugin is at
"%osgeo4w_root%\bin\gdalplugins\1.8\ogr_OCI.dll" instead of the
"%osgeo4w_root%\bin\gdalplugins" you report.
My PATH does not contain either of these plugin directories and
GDAL_DRIVER_PATH is not set. I have the following gdal packages installed:
gdal 1.8.1-1
gdal-oracle 1.8.0-1
gdal-python 1.8.0-2
gdal15dll 1.5.4-1
I repeated the test sequence in a newly installed osgeo4w environment,
though same machine, and got the same results. The host system is
Win7-Pro, 64bit.
cheers,
matt wilkie
Geomatics Analyst
Information Management and Technology
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
http://environmentyukon.gov.yk.ca/geomatics/
On 14/12/2011 12:20 AM, Rahkonen Jukka wrote:
> Hi,
> I made a new OSGeo4W installation with GDAL Oracle OCI driver.
> However, Oracle OCI was not listed as supported formats after
> installation. I could made it available by adding the plugin directory
> into path by giving SET PATH=D:\OSGeo4W\bin\gdalplugins;%PATH%. I
> suppose that setting GDAL_DRIVER_PATH might work too.
> -Jukka Rahkonen-
URL: http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20111216/466d9031/attachment.html
More information about the osgeo4w-dev
