[osgeo4w-dev] Significant Problems installing QGIS
Matt Wilkie matt.wilkie at gov.yk.ca
Mon Jan 31 19:12:23 EST 2011
Now verified. Same problem exists for package gdal15 and probably others.
The solution, as indicated in ticket #101, is to repack the archives
using msys tar & bzip2 and update the setup.ini md5 sums accordingly.
Jeff I advise you wait a bit until the server files are updated.
Frank: I am assuming you will regenerate the packages?
matt wilkie
Geomatics Analyst
Information Management and Technology
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
http://environmentyukon.gov.yk.ca/geomatics/
On 31/01/2011 3:53 PM, Matt Wilkie wrote:
> I'm just in the middle of troubleshooting some install troubles myself.
> My initial conclusion, not yet verified, is that the package for
> xerces-c-vc9 (xerces-c-vc9-3.1.1-1.tar.bz2) uses an unrecognized bz2
> compression dialect.  See http://trac.osgeo.org/osgeo4w/ticket/101.
> I don't know if this is what you are running into or not.
More information about the osgeo4w-dev mailing list
