[osgeo4w-dev] Significant Problems installing QGIS
Jeff Ruby
jgr007 at gmail.com
Mon Jan 31 21:41:46 EST 2011
Thanks much for the reply, Matt. I downloaded osgeo4w-setup.exe this
afternoon and was still having problems. I'll retry tomorrow at work
and post details of any problems I encounter.
On Mon, Jan 31, 2011 at 7:14 PM, Matt Wilkie <matt.wilkie at gov.yk.ca> wrote:
> Ahhh, there's a simpler route: download a new version of osgeo4w-setup.exe
> from the website and use that.
> (http://download.osgeo.org/osgeo4w/osgeo4w-setup.exe)
> ((looks like I need to figure out how to get a newer python library of
> tarfile and bzip2 for apt.py))
> matt wilkie
> Geomatics Analyst
> Information Management and Technology
> Yukon Department of Environment
> 10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
> 867-667-8133 Tel * 867-393-7003 Fax
> http://environmentyukon.gov.yk.ca/geomatics/
> On 31/01/2011 4:12 PM, Matt Wilkie wrote:
>> Now verified. Same problem exists for package gdal15 and probably others.
>> The solution, as indicated in ticket #101, is to repack the archives
>> using msys tar & bzip2 and update the setup.ini md5 sums accordingly.
>> Jeff I advise you wait a bit until the server files are updated.
>> Frank: I am assuming you will regenerate the packages?
>> matt wilkie
More information about the osgeo4w-dev
