[osgeo4w-dev] Download from mirror?
andrea antonello
andrea.antonello at gmail.com
Mon Mar 28 16:29:19 EDT 2011
Hi Matt,
that would be an great option. There is only one problem with it. It
is not installed by default, right? So for example in my case I have
no way to get the commandline installer without passing through the
gui installer.
Or is there a way for this?
Thanks,
Andrea
On Mon, Mar 28, 2011 at 6:58 PM, Matt Wilkie <matt.wilkie at gov.yk.ca> wrote:
> Hi Andrea,
> For a workaround until someone can (re)add this to setup.exe the command
> line apt installer can use "--mirror=URL" syntax. Local paths need to use
> "file:///d:/path/to/packages" format.
> The mirror used is remembered for future invocations, meaning you have to
> change it back to the default manually, e.g.:
> apt --mirror=http://download.osgeo.org/osgeo4w update
> pkg-apt: http://trac.osgeo.org/osgeo4w/wiki/pkg-apt
> cheers,
> matt wilkie
> Geomatics Analyst
> Information Management and Technology
> Yukon Department of Environment
> 10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
> 867-667-8133 Tel * 867-393-7003 Fax
> http://environmentyukon.gov.yk.ca/geomatics/
> On 18/03/2011 2:50 AM, andrea antonello wrote:
>> Hi all, how difficult would it be to enable mirror choosing for the
>> osgeo4w installer?
>> Since I remember the cygwin installer has the mirrors tab, I was
>> trying to understand if that one had only been "hidden".
>> Given all the problems that are occurring in several countries in
>> downloading from the main repo, it would be very nice to be able to
>> choose a mirror.
>> I tried to pass the mirror address to the installer via --site option,
>> but it doesn't work.
>> Thanks,
>> Andrea
>> osgeo4w-dev mailing list
>> osgeo4w-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/osgeo4w-dev
More information about the osgeo4w-dev
