[osgeo4w-dev] Re: cd before run
Matt Wilkie
matt.wilkie at gov.yk.ca
Thu Mar 31 11:51:59 EDT 2011
Hi Andrea,
"cd /d xxx" is change directory and drive
"cd xxx" is change dir on current drive.
However I would use pushd instead of cd, it has the benefit of working
with UNC paths as well (by automatically mapping to a free drive letter).
more info http://ss64.com/nt/pushd.html
If for some reason you need the drive/path of the batch file starting
udig use %0, as follows:
%~nx0 - the actual name of the batch file, regardless of calling
method (some-batch.bat)
%~dp0 - drive and path to the script (d:\scripts)
%~dpnx0 - is the fully qualified path name of the script
(d:\scripts\some-batch.bat)
from
http://stackoverflow.com/questions/357315/get-list-of-passed-arguments-in-windows-batch-script-bat/382312#382312
This is how the %OSGEO4W_ROOT% variable is set (see osgeo4w.bat).
matt wilkie
Geomatics Analyst
Information Management and Technology
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
http://environmentyukon.gov.yk.ca/geomatics/
On 31/03/2011 8:09 AM, andrea antonello wrote:
> Ok, I already have a problem with this.
> It doesn't work if the folder from which the application is launched
> is different from C: (a user reported it).
> In that case the changedir command won't end into the right folder.
> So the idea would be to change it to:
> c:
> cd "%OSGEO4W_ROOT%\apps\udig-dev"
> @start /B "BeeGIS" "udig_internal.exe" --launcher.ini beegis.ini %*
> But in that case if someone installs on a disk different from c:, that
> would not work also.
> Is there a variable that tells me the disk in which the installation occurred?
> So that I could do:
> %DISK%:
> Any other idea?
> Thanks,
> Andrea
> On Thu, Mar 31, 2011 at 11:44 AM, andrea antonello
> <andrea.antonello at gmail.com> wrote:
>> Hi, for technical reasons I need to cd into the apps folder before
>> exeecuting the application.
>> I changed the startup script to do so as:
>> it works. Just wondering if there is a more "windows" way to execute
>> an application from within a path.
>> Thanks,
>> Andrea
> osgeo4w-dev mailing list
> osgeo4w-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/osgeo4w-dev
More information about the osgeo4w-dev
