[osgeo4w-dev] python modules
John Callahan
john.callahan at udel.edu
Fri May 20 08:48:43 EDT 2011
Thanks for your replies.
I did look at setuptools (easy_install) but it will not install unless
python is in your windows registry as the system default python. I will
probably add the OSGeo4W python as my system default once it moves to 2.7.
I may have to do it now anyway. I haven't tried pip yet.
FYI... For the module pygments (required by a QGIS plugin), running "python
setup.py install" did not work. The error "can't open file setup.py" is
returned, which makes some sense since that file does not exist.
- John
On Thu, May 19, 2011 at 6:54 PM, Alex Mandel <tech_dev at wildintellect.com>wrote:
> I seem to recall if you can get setuptools (easy_install) or pip
> installed into the osgeo4w python then you can easily add some more
> stuff using the osgeo4w shell. Otherwise as Matt points out, grab the
> source for the package you want and in the osgeo4w shell run python
> setup.py install on it. As long as it's pure python code that should
> work well.
> Enjoy,
> Alex
> On 05/19/2011 03:38 PM, Matt Wilkie wrote:
> > Hi John,
> > There isn't yet an integrated method for installing python extras which
> > aren't part of the osgeo4w package system. A route that does work with a
> > bit extra twiddling is to register the o4w python as the system default
> > python[1], after which you can use the standard installers. If that
> > doesn't work or isn't acceptable you'll have to manually put it in
> > python's site-packages directory (there may be some more steps than
> > that. I'm not familiar with pygments).
> > [1] http://trac.osgeo.org/osgeo4w/ticket/114 - doesn't work on 64bit
> > systems, but if you study the .reg files one directory up you can see
> > how to make your own reg file to import manually.
> > matt wilkie
> > On 19/05/2011 11:14 AM, John Callahan wrote:
> >> Quick question regarding OSGeo4W. What is the best/preferred way to
> >> install python modules within OSGeo4W? For example, I use QGIS 1.7dev
> >> and tried to install the QGIS plugin "Fast SQL Layer." It could not
> >> install and returned that python module "pygments" must be installed.
> >> Doe sOSGeo4W come with a python module installer, or something
> >> similar? Thanks.
> >> - John
> osgeo4w-dev mailing list
> osgeo4w-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/osgeo4w-dev
URL: http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20110520/16d3e23f/attachment.html
More information about the osgeo4w-dev
