[osgeo4w-dev] Proposing OrfeoToolbox integration in OSGeo4W
Julien Malik julien.malik at c-s.fr
Thu Oct 20 15:12:27 EDT 2011
Frank,
Thanks for the info and for managing the access.
The packages are "promoted" now.
Best regards,
Julien
Le 20/10/2011 19:04, Frank Warmerdam a écrit :
> On Wed, Oct 19, 2011 at 9:43 AM, Julien Malik<julien.malik at c-s.fr>  wrote:
>> I have two packages ready: otb-bin and otb-python
>> They are tar.bz (compressed with the tar of msys), and next to them are the
>> corresponding setup.hint files.
>> Do you see anything wrong in this ?
> Julien,
> Based on a quick glance they seem ok to me.
>> How can I test this ?
> The normal practice is to upload them to the OSGeo4W release
> tree along with the setup.hint, and rebuild the *test* setup.ini file.
> The test regen is done with the following url (with obvious adjustments):
>    http://download.osgeo.org slash cgi-bin slash osgeo4w-regen.sh
> (I'm obscuring it a bit to avoid link followers triggering it frequently)
> Once the regen runs you will have a page with another link to
> promote the result to "release".  Don't following this link immediately.
> Then you can do an install using the test installer.  I think I use the
> normal installer, but with the -t flag though there may be other ways
> to do this.  Once you are happy with the result, then follow the link on
> the regen page to promote the test setup.ini file to production.
> Note that other packages who happen to be doing stuff at the same time
> can end up promoting your changes and vice versa.  Hopefully that isn't
> usually too serious.
> Best regards,
More information about the osgeo4w-dev mailing list
