[osgeo4w-dev] Dependencies for gdal not installed on 64-bit machines
Charles Karney charles.karney at sri.com
Tue Sep 20 17:49:53 EDT 2011
I can't get OSGeo4W to work on a 64-bit machine at all.  Here are the
steps I take
   Delete existing C:/OSGeo4W
   Download and run osgeo4w-setup.exe
   Select express install and uncheck all packages but GDAL
   Select install
   Start an OSGeo4W shell
   Run "gdalinfo"
I then get
   "The application has failed to start because ogdi_32b1.dll was not
   found."
Other observations:
* the above steps work OK on a 32-bit machine
* the installation appeared to install only 2 gdal packages (3 dlls).
   On the 32-bit machine several packages were installed alongside gdal
   (45 dlls).
It seems that the whole dependency mechanism is non-functional on
64-bit machines?
Any help would be appreciated.
Charles Karney <charles.karney at sri.com>
SRI International, Princeton, NJ 08543-5300
Tel: +1 609 734 2312
More information about the osgeo4w-dev mailing list
