[osgeo4w-dev] Dependencies for gdal not installed on 64-bit machines
Tue Sep 20 17:54:26 EDT 2011
Charles,
I've seen this from time to time too but it does not seem
to be specifically due to the 64bitness of the machine.
I was never able to figure it out though.
Best regards,
On Tue, Sep 20, 2011 at 2:49 PM, Charles Karney <charles.karney at sri.com> wrote:
> I can't get OSGeo4W to work on a 64-bit machine at all.  Here are the
> steps I take
>  Delete existing C:/OSGeo4W
>  Download and run osgeo4w-setup.exe
>  Select express install and uncheck all packages but GDAL
>  Select install
>  Start an OSGeo4W shell
>  Run "gdalinfo"
> I then get
>  "The application has failed to start because ogdi_32b1.dll was not
>  found."
> Other observations:
> * the above steps work OK on a 32-bit machine
> * the installation appeared to install only 2 gdal packages (3 dlls).
>  On the 32-bit machine several packages were installed alongside gdal
>  (45 dlls).
> It seems that the whole dependency mechanism is non-functional on
> 64-bit machines?
> Any help would be appreciated.
> SRI International, Princeton, NJ 08543-5300
> Tel: +1 609 734 2312
> osgeo4w-dev mailing list
> osgeo4w-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/osgeo4w-dev
I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
and watch the world go round - Rush    | Geospatial Software Developer
More information about the osgeo4w-dev mailing list
